I need a small access panel in my tiled floor. (not yet laid).
I really do not want to have a large tiled manhole cover in my kitchen floor. In fact, I dont want to see anything.
So my thinking goes that
1. I make an access door in the under tile ply wood and make sure the door is screwed firmly in place.
2.The tile that covers the access hatch, i do not use any adhesive. (Maybe some sand? to keep the level consistent with the other tiles)
3.Then I grout all tiles as normal.
For access, I remove the grout on just my one special tile, lift the tile using a suction cup, exposing the plywood hatch below which I can unscrew to open.
The tile in question will receive little if any footfall so the grout should be sufficient to hold it in place. (I think!!)
Will this work? Any better solutions? What could possible go wrong?
Many thanks.
Many thanks.
