Can you create a vacuum in the system (by bunging the cold feed and vent of the feed and expanison tank) to remove a rad or is it only allowed for one open end only-eg to change a rad valve?
also when creating the vacuum (bunging the 2 open ends in the tank) do you need to release some pressure, eg open a rad bleed valve, drain some water from a drain cock 1st or can you just open the valve, drain it (if changing the TRV) ...
thnaks for any tips...
