Creating an alcove?
29 Jun 2009
Lincolnshire
Not sure if i'm using the right terminology here but i'm fitting some sliding wardrobe doors, problem is the height of the doors doesnt match the height of my ceiling leaving an 186 mm gap.
I was thinking of creating a timber frame the width of the room and thick enough to take the track, then screwing it into the wall and joists in the ceiling then plaster before fitting the liners and tracks for the doors, Is this the best option? if so any tips or if not any other suggestions?
that's very much the right way to go.
When you install it make sure the frame is level, as are the tracks on the floor or your doors will start to slide about without any help.
You could consider instead of plaster using a timber face so can be painted or stained.
You may also find that the walls, either side are not level, again it's a case of putting up some timber upstands, so the doors close level to them.
Thanks for the reply, how would I go about fixing it to the wall? metal brackets?
I'll be using liners in the same colour as the door to frame it as fter plastering.
You don't need to use brackets to fix timbers to wall, you can if you wish but,
you can screw through the wood, drill and plug the wall, with suitable plugs depending on the material of your wall. Use a spirt level to make sure the upright is true.
Then fill in the screw heads and sand down, ready to decorate.
