Hi, I have a Medion PC, running Windows XP home edition, which has the HD partitioned into 3. This gives it the ability to simply restore C: drive back to day one, if it all went wrong by the way this is set up, however as I have had this PC for a few years I am now tempted to get a External HD to back things up in case the whole drive failed etc. I have tons of photos and stuff on the HD and although I am backing some up to CD's it would be nice to have this external one to fall back on. I am thinking of external as I have a laptop that I would like to back up too. I think I fancy a 500GB USB2 or firewire if possible (PC has USB2 and firewire but laptop has only USB2).
I have read loads about creating disk images but still have some questions, please can someone help with some answers for me.
I like the idea of just creating an image of my whole C: drive so that if it went wrong I could restore it in a few minutes but how can you access the image if you cannot boot up on your PC in the first place ie if C: drive had major boot problem corruption or something similar?
Could I create several separate images onto my backup drive, ie images of C: D: and E: drives and my laptop and maybe even an extra one of just my Documents all on the same backup drive and then pick which to use/retrieve?
If I wanted to keep backing up my Documents once a week would I have to do a new image each time or could I update the existing image?
Am I right you cannot do anything with the image itself you need software to use the image?
If I wanted to access a file in the image, is that possible or what would I do to get to this file in a say My Documents image?
Would I be better doing an image of C: drive but just copying the whole My documents to the backup drive for easy access?
If I copied the whole C: drive to the backup drive presumably I could access all the files but I could not restore my C: drive if it were corrupted with just a copy?
So is an image the preferred backup method?
Anything else you think I should be aware of?
What software would you recommend for working with images?
Any help appreciated.
