CREDA 42329 GAS HOB
13 Apr 2009
Northamptonshire
My ignition button for my gas hob has just decided it doesn't want to ignite any longer, can this be repaired or is a new part, if so, any idea of cost and availability.
Thank you,
Steve
It SHOULD be a simple repair, either broken wire, switch or ignition power supply, whether it will be cheap or not is more difficult to say until the fault is identified. Probably worth having it repaired if it is not too old. Is that model mains operated or does it have a battery that may have gone flat?
Look in the user guide, if you have one, or go on-line to the creda site.
