creda cond. dryer T620CW
31 Dec 2005
It runs for a minute or 2 and then cuts out.
Is there a thermal cut out on it as it will not turn back on straight away. It has to be left for a while.
There is a post about a similar problem and someone has suggested a relay problem.
Any suggestions would be helpful
Took a chance and replaced the relay.
Working fine now.
I also have the same model Creda. I had a problem with it heating up but after replacing the timer switch all seemed to be OK. However it still takes an age to dry clothes. I had a vented dryer before this and it was far more efficient. Is there something I should be doing? And yes I do empty the water tray and clean the condensing unit on a regular basis.
