grill went on fire a couple of months ago .... recently when grill is on a small electric shock can be felt aorund the steel rim encasing the hob and the hand of top oven door housing the grill. Time for a new oven? It's ten years old.
I can't say for sure if you need a new oven, but you should definately switch it off & disconnect it from the supply.It could be extremely dangerous for you or your family. If you think it can be repaired then call out an expert but given what you say about a fire the chances are it will need replacing. Your home insurance may cover it with fire being involved.
