creda t622cw overheating
14 Mar 2006
hi I,m new to this forum so bare with me.My tumble drier works fine for 2-3mins then cuts out.Ive tried replacing the 2 stats over the element ,but still the same,any help would be appreciated thanks
Blocked filter or vent kit outlet, check air is being forced out of vent while running if not that's your problem
thanks for your post ,checked vent ,ok.cheked relay ,ok replaced all 3 stats,no joy , any more ideas would be helpful,Ive run out of them
ahh this is a condenser dryer-yes
Does it stop completely or overhaet, 2 different symptoms/cures
If it stops after a couple of secs take out the condenser block then remove the little black plug from the small tube that sticks out the back at the bottom then run it with this cap off, see if it works and get back to me with results
Cheers tried that and still no joy,it runs for a few minutes and cuts out,if left to cool down it starts again but for less time before cutting out.Seems like its overheating,have you any more ideas?
Thanks for your time
Hi tried everything suggested and now beleive its not an overheating problem,tried disconnecting elements and still cuts out any more suggestions welcome. wife close to suicide.
In what way did you check the relay? The symptoms you describe are a classic sign of a faulty relay.
Hi I tested the relay by jamming it in the closed position and it still cut out
I still think the relay is at fault here.
Normal symptoms. M/c starts, runs till it tries to change direction then stops. Pressing start, it may run again for a shorter period or won't start for 5 or 10 mins.
Had a further think on this problem during the day and there's a possibility the motor and/or capacitor may be faulty. i.e. breaking down once heated up.
thank you sleepyhead you were right in the first place it was the relay sorry for all the messing about. apparantly this is a common problem with this dryer, thanks again
