I'm joining 2 x 2.5mm t&e together using crimp butt connectors. Having never done a crimp join before.....
Should I be using blue or yellow, I see both except 2.5mm cable?
Should the wires overlap inside the connector? This isn't possible in the blue but is in the yellow.
When testing the connection, just how firm should you be able to pull the wires apart before the connection fails?
