I'd like to add some insulation to the external walls in a 1930s semi with uninsulated brick cavity.
I though the best method would be to remove the existing, heavily patched, lime plaster. Assuming the walls are flat enough:
50 mm foil backed PIR
Tape seams and expanding foam around perimeter
2x1 untreated batterns, 3x1 if I can get them
Long screws through batters and insulation
25mm PIR
12.5 mm pb
I'm not keen on d&d as I've never done it and seems more likely I'll end up with an even wall.
If the walls are bad i could go with treated 3x2 batterns on the cold side and pack them level? 50mm PIR infill?
Parge coat needed with a cavity?
Cheers,
Dave
25mm PIR
12.5 mm pb
Cheers,
Dave
