CROSS DOWEL BOLTS AND THE DOWELS TO FIT,,10mmx150mm
5 Jul 2011
Manchester
could you please help me i need cross dowel bolts ,,(11 of),,10mm x150mm ,, i also need other screws ,,and slats ,, (again 11 sets of),,could you please point me in the right direction , thankyou very much ,,these are for double pine storage beds , i have 11 without any fixings,
Hiya Thanks for your reply , they dont stock bolts gig enough , i need m10 which are =150mm x 10mm ,with the dowels to fit them , but thankyou for taking the time , :D
Axminster do the cross dowel nuts at £6.30 for 2 steel ones but seemingly not the bolts. I shudder to think how much 11, with the bolts (which I can't find on any site) would cost. :eek:
http://www.axminster.co.uk/axminster-axminster-bed-bolt-nuts--packs-2-prod364429/
Is it not possible to contact the bed manufacturer (assuming it's not a self built bed) to see if spares are available? If not, I wish you luck!
I know it's a bit late, but found this site the other day.
They've got some good stuff.
http://www.ekmpowershop23.com/ekmps...d-fittings-set-knock-down-connectors-23-c.asp
