The chimney in my loft needs some attention as the mortar is little more than sand in most parts with numerous bricks needing replaced as they are also pretty soft and some have large chunks cracked off.
This has happened i assume because of long term water damage caused by bad pointing on the stack on the roof and old flaunching around the pots.
I recently got these fixed and was wondering what is best to do with the inside.
I was thinking of replacing the very bad bricks and repointing it all. or should i just get someone to render it. The mortar is so soft/ sandy that most of it could be raked out almost by hand.
Thanks a lot!
Thanks a lot!
