Crushed concrete or crushed Granite Type 1
14 Nov 2011
Essex
Evening All,
Im about to lay 150mm of hardcore for our extension floor base and have been asked if I need Crushed concrete Type 1 or Crushed Granite Type 1, this is then to have a sand binding over the top before dpm and concrete oversite is poured. Which one is the one to use or are both suitable?
Thanks in advance
concrete. and for blinding i’d use 6mm to dust or dust . sand is too fine.
What about insulation?
The plans state 150mm sand blinded hardcore, dpm then 100mm concrete, dpm 100mm Insulation underfloor heating pipes and then screed
Can you be assured that the crushed concrete is not contaminated? If so it will be OK
Blinding should always be sand - building or similar loamy sand, not sharp.
