Just trying to quote for a job.
Customer orginally had a lean to/summerhouse on the side of his house & this is where the cu was. Summerhouse fell down about 5 yrs ago & the electrician repositioned the cu on the other side of the wall in the lounge at skirting level behind the tv.
Customer now wants the CU moved again but into the porch which is about 5-10m away, around a corner & up the wall. Because he never thought about this before decorating the place & laying a soundproof floor (house has basement flat) & damage to decoration is not an option, I proposed extended wiring would run outside along a wall in trunking & then back through the wall into the back of the CU. I know it sounds ugly but potential visitors wouldnt see it unless they went looking. I can replace the tails & main earth.
Does running a whole bunch of CU cables in trunking outside sound ok ?
