A couple of questions about testing a CU replacement in the house
1. Ive got a supply for my garage on the RCD side in the house & then a non-rcd CU in the garage. Not sure if I have to record any test results regarding the garage supply on the EIC when testing the house CU replacement.
2. ON EIC what needs to be put in the 'Next Inspection Due' box when the wiring is already about 20yrs old. Do I put 10yrs (for domestic) & then put a recommendation for a re-wire somewhere on the EIC. Its my house & I've fully tested all circuits.
Heres a link that might be of use
http://energylinx.co.uk/electricity_distribution_map.htm
Cheers.
Cheers.
