I'd Ike to make a cupboard shelf unit approx 190cm h 60x60cm. I'd be using reclaimed wood mostly pallet wood and some stairs I found in a skip. They were made from pressure treated I think size is 5cm x 16cm I was thinking using that wood for the 4 legs. My problem is the longest bits are 80cm if I was to scarf lap joint 3 bits, would this be strong enough? Joints would 20cm long on ech bit. I'd glue and screw the joints to fix. The top half would be a cabinet and bottom would have a shelf or 2. It would be on wheels as well. Cheers
