Hi all
I have recently had the new house rewired and as part of that I have installed a lot of AV/networking etc. This is all terminated back to a central cupboard. The cupboard in question is in a bedroom as is actually the cupboard above the stair case. So the cupboard is raised off the floor level and covers the "sloping bit" which is hollow under the cupboard floor. This is where all the cables enter and come up through the floor of the cupboard.
The floor of the cupboard is made of tongue and groove floor boards, which are sitting at each end on the bricks surrounding the cupboard, much like our full rooms where the floorboards stretch from end to end.
There is no other joist running under the boards in the floor. The dimensions of the floor are about 80cm wide by 60cm deep.
I need to add a lot of equipment to this cupboard, I am planning to by a 19" rack which will hold the equipment like AV Receivers, power amps, network equipment and computers/servers.
Im a little concerned about how much weight the floor can take. It feels pretty solid and i can jump up and down on it but i know this equipment can weigh a a lot and will obviously be there over time.
I can't see an easy way to strengthen the floor either really. Am i worrying too much or should i be worried?!
