Not sure if this is the right section to be in, so apologies if not, I wasn't sure which one was best.
Looking for a bit of advice. I put a cupboard into my kitchen where the old hot water tank used to be, see here: //www.diynot.com/forums/viewtopic.php?t=122139 for pics, so you get the idea. The base of the cupboard covers a big hole which leads straight to underneath the floor. It's a raised wooden floor with just dirt/rubble type below. Normal Victorian setup if I'm correct.
All has been well with it since I put it in (about November 07) but this evening I took something off of the very bottom shelf/base and noticed that it was a little damp and sticky. I felt everything else on that shelf/base and they were all the same. I don't often use the stuff at the bottom so don't know how long this has been like that.
I'm guessing it's condensation, either because the base and back will be getting the cold air from under the house and the warm slightly damp air from the kitchen condensing when it hits the base of the cupboard.
So, I'm guessing I need some more ventilation in the cupboard, but I'm not sure where....
Should I put a vent in the base of the cupboard which would allow air from under the floor up through it?
Should I put a vent in the base of the cupboard door? Would this simply let slightly damper air from the kitchen into the cupboard and make it worse?
Should I put a vent in the base AND a vent in the door so that it breathes?
