Cure for Smelly Washing Machine
8 Jul 2004
Hello All!
I've got a smelly washing machine / drain, in a flat, and it is getting me down! I've looked through some tips, and the mass concensus say about using white vinegar and baking soda. Just wondered if anyone has tried this before, and, with my machine being a side loader, do i just pour vinegar/soda into the tray and then set to 90c wash?
Hope this makes sense - Thanks!
heeelllooo djc
i would assume the idea is to pour it in and let it work
if you add water you will just flush it out
perhaps leave for maybe an hour
i dont know the definitive answer but hopefully
this will get the debate going :D :D :D :D
is your hose at the back above the line on the back of the machine
and any traps on your sink
do you use your machine more than once a week
and if its a hook over hose the smell could be coming
out between hose and drain pipe
big all
put washing soda in put on 40 degree wash (no clothes) and when not in use leave the door ajar
Thanks for all the comments and advice!
I do use a hook over hose, and am in the process of using some odour eater solution to try to eliminate this. I may need to get a cover for this pipe, but not sure what is out there.
I will give the baking soda a go on a 40degree wash, and see what happens - If all goes well, I will let you all know!
Thanks!
p.s - If anyone has any other ideas, I'll be more that happy!
Cheers!
After looking at quite a few posts on the smelly washing machine saga I put a cup full of concentrated bleach on the highest 90 degree's cycle and it worked, that was a couple of months back now.
