Hi everyone. I'm renovating a 100+year old house which has widespread damp problems caused I suspect by various problems. I'm sure a lot were caused by condensation through poor ventilation and we're doing all we can on that score but we've still got damp which I would put down either to rising or penetrating damp. We've hacked everything off the walls inside the house and I've gone round with a damp meter. The worst areas are definitely low down which suggests rising damp to me. The house had a chemical DPC injected some years ago but that hasn't cured the problem and I'm reluctant to spend more money on getting it done again. I'm having the guttering replaced but that will take time to see if it cures the problem and I'd like to get the house plastered without waiting to see if new guttering helps.
So my question is this:
Is there anything which I can apply to the walls which will contain the dampness without removing it from the wall but prevent it showing through the plaster-i.e. prevent the visible signs of damp rather than curing it? I can batten some of the walls but it isn't practicable with all of them. Even applying a coat of render is difficult in some places because of door cases. In the past someone has applied a coating of a black substance which seems to be damproof according to the dampmeter. Is anyone aware of such a product, which I could apply and then plaster over as normal.
Secondly, could I fix insulation backed plasterboard to the walls(where I have the room) without curing the damp problem. This would help with the condensation and make the house warmer but I don't know if the damp will work its way through.
Sorry the post is so long winded but I think I have a number of different problems and need a variety of solutions.
All replies will be very much appreciated.
Keith
Keith
