How to start this post? I can cut and pitch the following, gable, hip, and irregular hip to a degree, but i am in essence still new to the cut and pitch game which is why I need the assistance of someone that has experience in this field.
I have been given drawings for the a conversion my employer has taken on and being the only chippy in the company it falls to me to work the roof out and pitch it. But I am somewhat stumped.
The property is a bungalow with a standard gable roof and a flat roof extension to the rear running the width of the house and the garage. Whilst the front of the bunglaow will remain intact we will be adding a hipped roof to the rear encompassing the garage and the existing flat roof extension.
The new hipped roof will be 900mm above the existing gable roof height and will be connected by way of a broken hip. The roof plan illustrates that the valley hip which is to be pitched to the existing ridge and intersect the broken hip is to put in at 40 degress "the all round roof pitch by the way is 35 degrees" whereas the external hip which pitches to the new ridge and is adjacent to the valley hip be pitched at 45 degrees.
This is where I am stumped, I would have thought that the valley and the hip rafter should run parallel to one another not have a 5 degree difference or is it because the hip and the valley are pitched at different heights then the 5 degree difference is the offset to allow the valley jacks to run true.
Thank you for your patience and I will be pleasantly surprised if anyone can help, cheers.
