Cut out for Belfast Sink
18 Jan 2006
Cumbria
I wish to make the cut out in a solid wood worktop for a Belfast Sink. Obviously I will need to rout this but I am not sure how best to do this considering I will require radiused corners at the back.
As they say in Parliament, "I refer you to the answer the Rt. Hon. Member has already given"...... Take a look here. The radius is the radius if your cutter which is why I use a 1-1/4in diameter cutter - very carefully! Other tjhan that you'll have ro make a template in something like plywood.
Scrit
