Hi I am going to be using some sleepers in the garden, the real used type with the tar coating or what ever they have on them, but I will need to cut them in some cases, so I have two questions.
1. How would you cut them, I was thinking of using a chainsaw, but can you cut fairly straight with that method(a couple of the cuts will be long ones, along the lengths). Would a circular saw be any good first from one side and then the other and then maybe either a hand saw or saber saw to cut right through or will oak beams burn the circular saw out quickly?
2. Secondly what would you use to coat the cut edge that would protect the sleeper as closely as its existing protection, ie I am trying to prevent my cut edges being the weakness that gives in first. Some of the cut edges will be in contact with the ground, with the project I am doing so I want something that gives a very good protection.
Any help appreciated.
