I had to cut through a 6” skirting, no cables visible, however mid way down some bright spark has laid 2 x cables, 1x 4 core and 1 x 8 core look like cat5 type of cables. One went to a sensor and the other went directly into the control panel zone box thingy which is on the wall in the next room, not the key panel.
The alarm went off on the outside bell only and the keypad went blank, so could not type in code.
The alarm stopped after around 10 minutes and did not go since then.
I was able to strip the cable and twist the like for like cables together and wrapped each one individually with insulation tape. The 3amp fuse along side the control zone box is good, could not see where the system enters the consumer unit?
Name on outside box is ITAL, name on keypad is Gardtec, the alarm is zoned in a 4 bed town house.
Would appreciate any advise as to how to re-instate system, Thank you , Tonyobm
