Just doing my bathroom and have a couple more rooms to tile so I invested in a wet tile cutter. It's not the most expensive - an Erbauer from Screwfix, but it seems an ok piece of kit. However the blade it came with seems pretty poor - it's blunt after about 10 tiles and has left small chips along the cuts which isn't ideal, but they're floor tiles so the edges will be covered. I don't want to continue doing visible areas though if the quality of the cut is going to be as average as it is at the moment.
My tiles are 66cm x 44cm, so tricky to cut. I'm going to replace the blade on the Erbauer and get a more pricey one. Anyone have any recommendations on a new 180mm blade that cuts porcelain nicely? I don't mind investing a bit into it as I've got more to do.
I've seen a Spectrum SL-Pro in Tool Station - supposedly the "ultimate tile cutting disc", and other people have recommended Norton and Marcrist (although I've seen some bad reviews on these).
Any experiences you can share would be much appreciated.
On another note, I've also go to cut radiator pipe holes in 1 tile and a cut out for a shaver socket - any tips on porecelain this thick/tough?
