Cutting a joist
17 Dec 2014
Warwickshire
I have a badly rotten floor joist. I've decided to cut out the rotten section and replace it with some new 3x9. The floor above is a tiled bathroom which I really cannot afford to rip out and re-tile. As such, I can't lift the floor boards above. The joist is parallel to an external wall with only about 2 inches between the wall and joist.
Any ideas how I can cut this fairly cleanly? My only current thought is a wire saw looped over the top of the joist cutting down. Any better ideas?
recip saw with long blade
osccilating saw with blade at 90% degree to body
jigsaw and finish with flush cutting blade
http://www.ebay.co.uk/sch/i.html?_f...+Dewalt+Flush+Cut+Jigsaw+Blade++Wood&_sacat=0
you will temporary have to tie say 5 joists together underneath each side and possibly acropropp to stop it moving
and a bit off 7x2 either side will normally be far easier to get in as you can feed it in fairly flat and rotate it to fit
Thanks for that. Flush cut blade looks interesting. Am I right in thinking that the intention is that the blade protrudes forward of the front guard on the jigsaw such that it can cut right up to the floor boards?
yes it sits forward off the machine but you need a jigsaw where the blade goes in without rotating through 90 degrees unless you can remove the baseplate and refit with a blade in place
and without a metal guard to get in the way
As per woody.... Why not leave the joist there and fit a new one beside it? Obviously make sure the rot won't continue tho.
