Cutting a radiator off a wall
26 Sep 2013
London
I'm redecorating a room with a small radiator on it. After trying unsuccessfully to remove the radiator it looks like the plasterboard on the wall is blocking the bracket.
I'm assuming what has happened is someone put plasterboard on the walls, didn't bother taking the radiator off first and simply slid a bit of board behind the radiator and screwed it into place. Behind the radiator is the only part of the room where the wall isn't new.
So how can I get the radiator off? There is next to no space behind the radiator to get any tools behind it. Maybe 10mm between the back of the radiator and the plasterboard.
I don't really want to rip the wall apart but short of trying to cut a radiator off a wall I'm not really sure what to do. It's an old radiator so I'm not bothered about replacing it.
Sorry, I edited my original post while you were replying
use a couple of blocks and a short baton to lever the rad upwards about 10mm then pull it towards yourself.
Don't think there's the space to move it up 10mm, the plasterboard looks to have been placed hard up against the bracket. Tried lifting it but it doesn't shift.
Can you not just leave it and decorate with it in place?
Yep, it's just been painted over a few times and could do with being tidied up a bit or replaced. Think I'll end up having to leave it because it sounds like too much of a hassle
I would have thought JimCrow's idea should work, the brackets welded to the rad should be able to "bite" into the edge of the plasterboard and allow the rad to lift enough to come off the bracket on the wall.
Try a car jack & a piece of wood under the rad, it will damage the plasterboard but you can fix it when the rads off the wall.
