Cutting a slot in the bottom of a door?
31 Mar 2021
I need to cut a slot in the bottom of a 35mm thick oak door (it's a 838x1981mm door) to accommodate an anti warp insert. The slot needs to be 10mm wide and 17mm deep.
I'm trying to work out the best way to do this but not having mush luck. I've looked at slot cutting router bits but most of these can't cut deep enough. I could get a 10mm straight router bit and use the router tilted over 90 degrees but I think this will be a bit hard to handle, and I assume routers aren't really designed to be used on their side.
What options do I have to do this?
Fix a thick, oversize fence plate onto your router, say 18mm plywood about 200 to 250mm square with lightly chamfered edges. That will support your router. It is how we deal with slots for drop seals when they've been missed in manfacture or misrouted or we need to shorten a door (it happens, albeit rarely). Grooves are routed with the doors laid flat on a pair of trestles. Works better with a knob screwed onto it but you still need to support the weight of the router
