cutting and pruning
23 Mar 2005
when is it the best time to cut back on shrubs and why.Also the same question on cutting the lawn.
If your lawn was last cut Autumn time and now is 3" or more it's due a cut, but put it on your highest setting.
I note they didn't tell you why? Generally pruning is done in Autumn/early Spring because the wood is less sappy or dormant so it's less likely to bleed. Some woody plants can literally bleed to death if you prune them when they're growing. And the weather is too cold in winter.
not knocking your reply eddie, its a good rule of thumb, and many people get a little over complicated with pruning etc!
Yeah, did you know the RHS did a trial regarding pruning roses, and found the bst way to do it was with a hedge trimmer!!
I have a Budlia (not sure of correct spelling) which has grown quiet tall as it has'nt been cut for many years. It does not produce much flower.
Is this because it has not been pruned/cut back?
Can I cut it down low - would it recover such a shock?
When can I do it?
When can I do it?
Yep, now, cut it back hard.
When can I do it?
Buddleja (not being picky just showing spelling) is amazing for new growth. Now is the time to cut it, it will recover from just about anything you do to it except oull its roots out!
Many thanks for your reply and thanks for the correct spelling.
I'm not touching the roots so I'll have a go.
