Cutting angles
1 May 2006
OK dummy is officially out of the pram with this! I need some advice on how to cut internal and external corners on coving, I took the same approach as I would have for skirting but I'm pretty sure my problem is where Im laying the coving flat to cut it.
Anyone have any advice on how to cut internal and external angles for coving?
You sit the coving on the cutter as you would sit it in its final position. You don't lay it flat on the ceiling now do you! :rolleyes: :LOL:
thanks I will try this tomorrow evening and hopefully dummy will remain in :oops:
My mitre guide says it should be upside down when cutting it?
Have a look back on the Plastering site.....
