Hi All
Got a bit of a dilemma which i was hoping someone may have some tips on how to handle. We recently did a renovation, new LVT click flooring was fitted and architrave was installed on top. All good.
Due to issues with the subfloor, I will be removing all of the LVT click flooring and skirting, a self levelling compound will be poured and a LVT glue down flooring will be fitted. The final floor height will be about 6mm higher than current. The floor fitters have advised they will only scribe around architraves.
In a ideal world, i would like the new LVT floor to be slid underneath the architrave for a better finish. However, my issue is that i dont know exactly what my final floor height will be so i cant pre-cut the architrave (in fear of cutting too much off). If i choose to leave the architrave as it is and then pour the self levelling, some of the architrave will get buried in the self levelling compound. I'm not sure if this is a good thing or not.
I was thinking i could allow some of the architrave to get buried in the self-levelling and then come along with a multi tool and run it flush against the floor so a few mm is shaved off the architrave. Would this work? I have approx 10mm of self levelling being poured and then a 2.5mm floor being glued down.
Any other ideas how i could tackle it? Of course worst case scenario is the floor fitters just scribe around the architrave and door stops. Skirtings i am doing again so not concerned with that.
Thank you
Thank you
