Right, I know I'll get loads of flak for this and probably start another asbestos debate, nevertheless, here we go...
My garage roof is a prefab 70's type with corrugated asbestos roof, I've recently been given 4 sheets of same, to replace some damaged areas.
The damage occurred years ago (80's) and the broken sheets were replaced with cheapo pvc which is now cracked and broken and will have to be replaced as I am turning the garage into a music rehearsal space. I need the roof to be made from one single material, otherwise I will have 'weak spots' in my soundproofing (don't worry, this will be more than just a corrugated roof).
I've enquired at local roofing suppliers at the cost of eternit sheets and have been quoted £38 each, so the choice of spending £150+ to fix the roof or using free materials is a no brainer.
The sheets I've been given were stored in an outbuilding, under cover and are as new, they haven't been used at all and are in good condition. The only problem is that they are 10ft long, whereas the existing roof is made from 8ft sheets.
So the tricky part is that I have to cut 2ft from the end of each sheet.
My plan is to take them out to the alley behind the house. Wear suit, gloves and mask, and cut them by hand. I will paint one side with bitumen paint before cutting and will wet the other side. Afterwards I will paint the cut ends and bag everything up for disposal: cut-offs, tools, mask, gloves, the lot.
So far so good, but the questions I need answered are:
Whats the best tool for the job? Maybe someone on here used to use these years ago, whats the best way to cut it? Hacksaw?
Which type of mask to use? Will a 28 day disposable MDF mask suffice for the job? http://www.screwfix.com/app/sfd/cat/cat.jsp?cId=A331070&ts=00510
Constructive answers please, not a load of repetition about airlocks and needing £8,000,000 insurance etc...
Cheers
Cheers
