The best method I found when I was making cuts in conti board is to use my table saw with a 80 tooth blade made perfect cuts.
Not much help if you dont own a table saw but a circular saw with a blade made for conti/laminate cutting is the same idea.
I also had great results using my jigsaw with a clean cut/fine blade.Basically lots of teeth is the answer
