Cutting copper pipes
19 Apr 2006
I have two 15mm copper pipes (hot from a combi and mains cold) which are a few mm apart. I want to cut them and replace a section with new pipes with T-joints etc. I have only ever cut pipes using a traditional pipe cutter (to give a clean edge) which you spin around the pipe. However there is not room to use such a device. My questions are:
1) How can I cut the pipes and
2) What type of joint would be needed to join the pipes at the new cuts? I want to use copper push-fit if poss but obviously need the joint to be completely water tight
Thanks in anticipation
if u cant move the pipes apart then u need a hacksaw and a file to debur them after.
join them with what ever u want, pushfit, solder etc.
Thank you.
You can't beat experience.
Sorry to ask, but, do you have any views on my other question posed today re the cast iron loo pipe?
ta
