Cutting down kitchen cupboard
W
wkdhd
I am redoing the kitchen and have to make a wall cupboard about 4cm narrower.
What I am concerned about is chipping the laminate. It will be open shelves so I don't have to worry about the door.
Only the faces inside the cupboard and under the shelf will be particularly visible so I can get away with some chipping on top and underneath.
I'd rather use a circular saw, I know if I hand saw the edges won't be straight. Do I need a specific blade, I just have the blade that came with it when I bought it years ago.
The cupboard is B&Q cheapy so it is mdf with a laminate of some sort on top.
Thanks for any assistance on this
Hi
the best way by far to get these shelves chip free is to jut just off the length you require and then rout the edges straight with a router and a good quality blade .. this will give you a clean edge and it will be square.. a circular saw will chip the topside of the cut , even with a very fine tct blade..i am assuming you are a diy'er .
Thanks loosenup, I hadn't thought of using my router, I'll make sure I get a decent cutter for it.
They aren't plain white inside but a weird chequer pattern. I think the caulk would be a bit obvious
you should be able to find differing colours of silicone?so maybe 1 that matches your boards can be found?.
