Hi.
I need to cut a 300m duct into the workshop roof ..... the roof is made of cement asbestos corrugate roof panels .
The plan was to mark the hole then cut the hole by using a air saw and spraying the area of the cut with soapy water...will be suited and booted using my painting mask and coveralls
after the hole is cut and the 300mm ducting is trial fitted ....what is the best method for sealing to the roof ?
our initial thoughts were to secure ducting from inside by bracing of the roof beams ...then either use fibre glass and resin (marine spec) or use a polyurethane sealant ? there will also be guy wires supporting the pipe from the outside
Tommy
Tommy
