I'm trying to cut out a much larger access hatch in box section in a bathroom hiding the various pipes, water meter etc. Rather than being plasterboard, this box section is made of material which is grey and fibreglass re-inforced. It's about 10mm thick and hard as nails. It's also quite brittle - such that I would imagine score and snap would work if you were just cutting a sheet of the stuff to length, rather than having to cut in situ.
My best guess with it being a bathroom is its some sort of cement board but, I have used cement tile backer board before and don't remember it being this difficult to cut.
A hacksaw blade will cut it but it's hard work - it cuts at roughly the rate of aluminium of the same thickness. The grit edged blade in my Bosch multitool also makes an impression, but is also very heavy going. Any other blade blunts quite quickly. I have about 4ft to cut in total, so wondering if anyone has any better ideas for next time I attack it?
My only remaining ideas are to buy a load of drills of the same size and chain drill it, or perhaps see if my jigsaw is any better.
Thanks!
Thanks!
