hello,
could you tell me the method for cutting a small square in the middle of a granite tile.
for something small like the size of a single socket, in the middle of a 305x305. I understand that some use an angle grinder with a diamond disk, but a 115mm will be to big I think, and not cut that small...holding it up to the tile I can see this.
I have seen some of the smaller stone cutting disks made by Marcrist, 80mm and 85mm but they have a 15mm bore. is there a smaller grinder that people use? to take these..
On another point can you explain how some of you get a perfect strait cut with an angle grinder, as I have read that some don't use a wet saw and just prefer to use a grinder, do u clamp it or what.
Cheers guys
D
Cheers guys
D
