Hi, I'm looking for advice on drilling a hole in paving blocks (std UK 200x100x50mm) to install a recessed light fitting. Assuming the hole is drilled into the centre of the block what is the maximum diameter hole I can drill without risking the block breaking either during the drilling or in situ later? I don't want to select a light fitting that is too big and cause the blocks to break. Thanks!
