I need to paint a house.
I went into Brewers (trade decorating shop) and asked for the tools I needed to do my mist coat.
For cutting in the guy suggested a very thin brush and to take the roller right up to the edge of the wall..
Now I see that you might use a thick brush and then take the roller as close as you can to the wall - overlapping the brush mark (so as to leave as little brush marks on the wall as possible).
However,the brush I got is so thin (maybe an inch?) that it will be a challenge for an amateur like to to get the roller so close without bumping the nearby wall - maybe not so important for the mist coat where you will run around doing everythign quickly - maybe more important for final coat where you may not want the roller to touch the other wall.
Is such a small brush standard for cutting in and am I over thinking it? I can alwaysbuy another brush.
By the way on a mist coat - is it ok to do all the cutting in for a whoel room and then roll it - or because it will dry quickly, are you better of cutting in each wall as you go so you don't end up paiting over paint that is already dry?
