Cutting lead/iron pipe-how to?
19 Apr 2004
London
Have had a main pipe burst and need to mend myself as insurance expired.
Have only cut copper pipes which is easy enough but does an old lead pipe need something special? It could be made of iron/steel also? Waterboard will not repair as it seems to have burst under our doorstep. Angle grinder do it?
If i can repair it i will otherwise renew whole length of pipe through downstairs to stopcock (internal)[/b]
Consider using one of those new 1mm thick slitting discs in a 4 1/2" angle grinder.....they will cut through most materials, and heat build up is minimal.
John :)
Might be wrong mate so do not quote me but when it comes to lead i beleive it must be replaced in a situation like this especially on water.
If your kit doesn't run to an angle grinder, a hacksaw with a decent quality blade will do the job.
(IME The Wong Foo Ying Tong £1 for 10 blades brands tend to shed their teeth when shown anything harder than tinfoil. The hardened teeth remain stuck in the work, and quickly blunt the next blade you try)
