Cutting notches out of existing coving
16 Oct 2014
Gloucestershire
Hello,
We are looking to put a new curtain track up in a bay window.
Unfortunately the brackets are taller than the gap between the top of the window frame and the bottom of the (plaster - I believe) coving.
I was wondering whether it will be possible to cut notches out of the coving with a Stanley knife to fit the top of the bracket. We're talking about a notch maybe 20mm tall and 15mm wide.
Am I likely to come up against any major issues attempting this or is there a better way that someone can propose!
I will take some photos if that helps explain the issue.
Thanks,
Anthony
Stanley knife or nice sharp chisel should do it, might get a little bit of a rough edge but a bit of polyfilla should sort that.
Why not post a pic - there are different kinds of coving from plain modern scotia's to highly intricate Victorian types. Perhaps there's another method of fixing without cutting the coving?
