I've got some 15mm copper pipe fitted very close to the wall (15mm clearance). I want to cut it leaving a clean enough cut for a push-fit connector. There are pipes directly below, so a hacksaw won't be an option. At one end of the stretch is a compression fitting (at the stop-cock), at the other is a very complicated arrangement of soldered tees and elbows. Slightly to that side of the place I want to cut is a pipe passing close over the top of the pipe in question, meaning that even if I disconnect at the stop-cock, it probably won't pivot out far enough to admit a pipe cutter between the pipe and the wall.
Any intelligent suggestions as to how to cut this?
