For a welder to be able to cut piping at an angle I believe there is an aid called a 'wraparound' which is available in different sizes. Can anyone tell me where I would buy such a thing, or is it something that a tradesman would make himself?
You would make them yourself normally. thin sheet, flexi plastic, card... whatever.
Do a flat pattern development of the angle, the more points the better.
Then shape it around the pipe you need to cut. Mark it with some french chalk, marker, scriber.... and cut away.
