Hi All
I have a large piece of calibrated victorian grey slate (900x450x25) that I need to cut into a fireplace hearth (750x300) and mantel (850 x 150).
I've got a plasplugs 5" 'master' wet cutter, and 4" and 9" grinders with segmented diamond blades. What's the best way to get a good (exposed) finish? The wet cutter tends to wander on long cuts, and I seem to get stripes across the cut edge.
Can you use a batten or angle iron to keep a grinder straight - would the cut face be better?
Should I cut slightly oversize and use a polishing pad?
I thought about renting a pro cutter (one with the fixed table and moving motor) but I can't find one that will take 900mm.
Thanks in advance
bsr
Thanks in advance
bsr
