I have two holes in my plasterboard wall, with satellite coax cables coming through them.
At present the holes are a bit rough and just look horrible...
My plan is to fit a double sized blank electrical wallplate (147x88mm) over the top of them and have F-type sockets on the wallplate.
What i want to do is to cut out a slot between the two holes to give the cables more room to move when fitting the wallplate...
Black is the existing holes (12mm in diameter, 97mm centers), Red is the section I want to remove.
What is the easiest way to do this? (Never worked with plasterboard before)
