I want to fit a wall safe, and need to cut a square hole in the inner leaf.
My inner walls are made of dense concrete tri-wall blocks (not lightweight foamed concrete). They have an 18mm sand and cement render with a skim of hard plaster.
For my first attempt, I used a small angle grinder to cut the outline and thought I could cut through the rest with a bolster and club hammer. However this made vast amounts of gritty dust and the bolster would not cut the slot like I wanted. I ended up drilling a line of 12mm holes and joined them up with the bolster, the blocks were still inclined to break rather than cut.
Is there a sensible way to do it? I believe there is a TCT chisel for an SDS drill, but I do not have one. I have a couple more to fit for guest use but have stopped due to the grit dust and time.
