I'm constructing some racks in my garage and will need to cut some 3mm mild steel (flats and angle, probably 30-40mm widths). Assuming (rashly) I measure it all right first time, I probably need to make about 15-20 cuts.
Is this a job for a hacksaw and some elbow grease or would most people use an angle grinder?
I may well be getting the steel from a local fabricator down the road, and I'm sure they'd cut it for me, but where's the fun in that?
I'll also need to drill it, and I'm planning on getting one of those drill stands that you can find your corded drill to. Are they any good, or should I fork out for a decent pillar drill?
