Cutting stool legs?
29 Jun 2006
Birmingham
Hi can anyone recommend what kind of saw to use for cutting short some metal bar stools? I bought some from ebay for my breakfast bar but they're a little too high for the worktop so I was thinking of taking off a couple of inches from the base. They're tubular steel roughly 2mm thickness.
heeellloo Akshay :D:D
providing there is no structural connection in the area concerned
i would suggest place several layers of tape over the area to want to cut mark all round and cut with a fine tooth hacksaw
the tape will not only help guide the blade it will help stop accidental dammage to the surrounding area :LOL:
Is it at all possible to cut the 4 legs at once (stuck together with tape, perhaps? That way they should all end up the same length and hence no wobble.
A hacksaw fitted with a 24tpi blade will work a treat. Dont forget to clean up the burrs from the cut to prevent it damaging your flooring.
Like Bigall mentioned, a bit of masking tape or similar will protect from a stray hacksaw blade
^woody^ said:
Can a pipe cutter cut square tube? :confused:
There's no such thing as square tube, but if you mean square hollow section steel, then the answer is no.
gcol said:
Funny - these guys reckon there is. :confused: http://action-storage.co.uk/benches/squaretube.asp ;)
Oh really? Is this the dictionary according to some-randomly-selected-company-that-happens-to-have-a-web-site?
I notice that their conviction is so strong that they have to call it "Square Tube".
If they were right, then regular tubing would be called "Round Tube". :rolleyes:
