Due to a slight change in the arrangement of wall units in the kitchen, I need to redo a few of the tiles which had nicks taken out of them and are now rather unsightly. The tiles are unfortunately 20x30cm (Plain white gloss), which seems to be a "strange" size according to all the local shops!
So it looks like I'm going to have to cut down 25x33cm tiles...
To do this I picked up a cheap tile cutter (£2 job from B&Q - bit of plastic with a blade as a wheel on the end...) - no doubt this will be fine for simply cutting down to 20x30, however on a couple of the tiles I need to cut an L-shape around a power socket. Will I be able to use this tool to achieve this, or will it be a disaster! I'm guessing an appropriate jigsaw/coping saw blade may be too expensive just to cut 2 tiles?! Alternatively are a shop likely to cut them to size if I give them the dimensions and ask nicely?
Thanks!
Thanks!
